![]() Honorary Subaroid ![]() ![]() ![]() ![]() ![]() ![]() ![]() ჯგუფი: Member ნიკის ჩასმა ციტატა გამოხმაურებები: 4,006 რეგისტრ.: 18-April 10 მდებარ.: Tbilisi მომხმარებელი № 1,023 ![]() |
BOSCHMANN PCH-4480LX
SPECIFICATIONS: - Maximum Output: 900 watts, 4 channels - 4 ohms MAXIMUM Output @ 0.03% THD: 160W + 160W, 290W + 290W - 4 ohms BRIDGED Output @ 0.02% THD: 150W + 150W - 2 ohms WRMS Output: @ 0.1% THD: 85W x 4CH - 4 ohms WRMS Output @ 0.03% THD: 60W + 60W, 90W + 90W - Low Pass Filter: 40Hz-150Hz - High Pass Filter: 80Hz-1.2kHz - Frequency Response: +1/-1 dB@ 5Hz-50kHz - Signal To Noise Ratio: >100 dB - Stereo Separation: >80 dB Stable Into 2 ohms Operation - Input Sensitivity: 200mV-3V - Input Impedance: 22k 0hms - Operation Voltage (Negative Ground): DC 12V - Speaker Impedance @ Stereo Driven: 4 Ohms - Fuse Rating: 40A x 1 DIMENSIONS: - WxHxD: 273x62x350mm ფასი 200 ლარი ![]() |
